@Budek
It works fine for me.
Check this version.
It is practically the same.
Only the led flashes quickly during setup.
Smart DGM DSG-W162
- Attachments
- DGM-W162.rar
- (527.44 KiB) Downloaded 180 times
Wgrałem z Twojej paczki updater, następnie soft.
1. Nie wyświetla mi się strona pod 4.1
2. Na szczęście otwiera się OTA.
/Budek
- Attachments
- Screenshot_20210106-191120_Chrome.jpg (56.99 KiB) Viewed 3423 times
Ok. Mam.
Dziwnie to jakoś poszlo. Jak wprowadziłem w tryb konf. To pokazal mi ze jest połączony z moim wifi..... wpisałem dane. Zapisal. Zrestartował się i dopiero zarowka mrugnela jak przy kalibracji.
Tak czy owak teraz działa.
Dziwne, że po wgraniu softu docelowego nadal roglaszalo sie ap updater.... a nie docelowy ap.
Ważne że dziala.
Dziekuje za pomoc !!
/Budek
Hi Elmaya,elmaya wrote: ↑Mon Jan 06, 2020 10:41 am using the pulse counter channel for the energy meter and a temperature and humidity channel for voltage and wattage.
It is not an ideal solution but waiting for the implementation of energy meter can be a temporary solution.
To access the Wi-Fi configuration, press button for at least 10 seconds, Led winks in wificonfig.
in the configuration page enter the data for "suplaServer, Email and Supla Device Name (name with which it will be seen in the cloud and DHCP)"
read-only field with the latest Supla connection state.
expectedVoltage -- for calibration.
expectedActivePower -- for calibration.
clear counter -- reset pulse counter.
calibration process:
connect a resistive load with a known consumption, for example a 60W bulb.
access wificonfig (button pressed 10 seconds)
in the "expectedVoltage" field set the voltage of your line for example 227.
in the "expectedActivePower" field, set the consumption of the connected load, for example 60.
press save.
The procedure takes about 15 seconds, then the device restarts and the readings will be correct.
the calibration is only executed if there are data in both fields "expectedVoltage" and "expectedActivePower"
This allows for example to change the Wi-Fi network without recalibrating.
Active Power (W) reading in the humidity channel will be /10
11.1 corresponds to a consumption of 111W
OTA update http://XX:81/update -- xx = device ip. for example http://192.168.1.22:81/update
user: admin
password: pass
DSG_W162_V4_DOUT_8Mbit.rar
At the very first begining I would like to thank you for your contribution and great firmware for DSG-W162 and SP111 sockets.
I have a question about socket state after recover from power loss. Is there any chance to have state of power socket to ON after power back on?
upload GUI Generic and you can set as you want viewtopic.php?f=11&t=7133
